I have seen a few posts about removing and fixing dash clock, I have even had mine out a few times and cleaned the connectors and replaced the bulbs with leds.The only issue will be getting another units on its own, you may have to buy a second had full set of clocks and take out what you want… or replace the parts around so you get what you want. As far a getting a new OEM gauge I’d say the cost would be high. It may also be possible to get an after market replacement but I have no idea how you would go about fitting that. Best of luck.
